The following table summarizes the Passpoint Policy configuration mode commands:
                         Command  |
                         Description  |
| 3gpp |
                         Configures a 3gpp (3rd Generation Partnership Project) PLMN (Public Land Mobile Network) ID  |
| access-network-type |
                         Configures the access network type element in this hotspot  |
| connection-capability |
                         Configures the connection capability element in this passpoint policy  |
| domain-name |
                         Configures the RF Domains to which this hotspot is applicable  |
| hessid |
                         Configures the HESSID (Homogeneous Extended Service Set Identifier) for a specified hotspot zone  |
| internet |
                         Advertises the availability of Internet access in this hotspot  |
| ip-address-type |
                         Advertises the IP address type used in this hotspot.  |
| nai-realm |
                         Configures a NAI (Network Access Identifier) realm name and enters its configuration mode  |
| net-auth-type |
                         Configures the network authentication type used in this hotspot  |
| operator |
                         Configures the operator friendly name for this hotspot  |
| osu | Configures an OSU (online sign up) SSID/provider and enters its configuration mode |
| roam-consortium |
                         Configures the list of Roaming Consortium OIs (Organization Identifiers) supported on this hotspot  |
| venue |
                         Configures the venue group and type for this passpoint policy  |
| wan-metrics |
                         Configures the WAN performance metrics for this hotspot  |
| no |
                         Removes or reverts passpoint policy configuration  |
The input parameter <HOSTNAME>, wherever used in syntaxes across this chapter, cannot include an underscore (_) character. In other words, the name of a device cannot contain an underscore.
For more information on common commands (clrscr, commit, help, revert, service, show, write, and exit), see Common Commands .
